Turbo gone crazy
Turbo gone crazy
Ok so im running on the highway an started to boost i whas currently at 16psi, on first the turbo gauge tells me im at 16psi, when i get second i see that mi boost gauge reads 20psi and in third 28, hmmmm i start to get worried and turn down the **** to 10psi, when i did it it threw 10 in first, 15 in second and 20 in 3rd.[:@]
Now today i try it again and every gear throws 10 psi.
Can anyone help me here im worried, i think i broke something
[]HELPPPPPPPPPP!!!!!!! AHHHHHHHHH[]
RE: Turbo gone crazy
Hook one gauge up to the hose that goes from the compressor housing to the wg acuator, then hook the other up to the intake manifold. The on on the intake manifold will give you a percise hg and the other will give you a positive boost pressure reading.
did this happen right after installing the boost controller? if so you probably have the vacuum hoses reversed.
does the boost only go high for a second then fall back to normal? if so it could be boost spike.
try to report more info
michaeljr5
05-20-2006 01:45 PM
