TURBO MALFUNCTION
Old Aug 21, 2008 | 05:56 PM
Default RE: TURBO MALFUNCTION
Try using a higher grade, then after the tank is finished, remove the battery for 2 mins, and keep using the high grade.
You might have a boost leak too.
Old Aug 21, 2008 | 06:14 PM
98TSi awd's Avatar
k thanks ill try that andill check the boost leak once i start goin to school....but do you think it could be because i dont have a turbo timer either so stopping my turbo while its hot happens alot which might have ****ed it up
Old Aug 21, 2008 | 07:47 PM
eh, i meann you should leave your car running for like 30 seconds or so after youve just run it hard. But that wont cause really bad failure. Unless the turbo is just that old that its going. Do you hear any whine noise while the turbo is trying to spool?
Old Aug 21, 2008 | 08:00 PM
dsm1990gsx's Avatar
Also try checking the turbo for and shaft play up/down and in/out.
Old Aug 26, 2008 | 02:17 PM
98TSi awd's Avatar
nothing seems too out of the ordinary besides the boost everything sounds normal but it just doesnt feel right...thanks ill check for shaft play
foolane
May 14, 2013 06:16 PM
gant
Apr 3, 2007 11:29 PM
Dookitchen
Oct 9, 2006 12:54 AM
MissFox98Spyder
May 26, 2006 03:58 PM
boosty
Sep 17, 2004 06:17 PM
