twin turbo eclipse
Old May 1, 2007 | 11:36 AM
  #31
Dusty Eclipse's Avatar
Default RE: twin turbo eclipse
TE, yes, but its a rotary motor... not an I or Vform
Old May 1, 2007 | 02:29 PM
  #32
ORIGINAL: TheEngineer
look, the thing it, you arnt gonna put two large turbos in there becuase of space. I have seen it done. But its far more efficient to put one large turbo than it is two smaller turbos. And the max HP is alot greater. Believe me just cuz its two turbos, doesnt make it better
The HKS upgraded twins for the supra make 800-900HP but the single kits can make more and the HKS twins cost more than double.
Old May 1, 2007 | 02:31 PM
  #33
ORIGINAL: Dusty Eclipse
the supras twin setup is the same way as an RX7. they use on manifold there is onturbo on one end and one on the other. They are sequiencial so one spools first at lower RPMs and the other spools later to give more top end that is how those car work. a I4 motor should be done the same if you are going to TT it. the V motor is different for obvious reason.
Old May 1, 2007 | 03:19 PM
  #34
brknhrtdpimp1489's Avatar
so emonz if you put a smaller turbo to spool first until the larger turbo has enough pressure to spool up would that work or would it put too much load on the smaller turbo one the larger one started spooling...
Old May 1, 2007 | 04:02 PM
  #35
I think he said that he wouoldnt suggest doing a TT setup on a GST\X regardless.
Old May 1, 2007 | 04:16 PM
  #36
no i know that im mean im saying on a car that is naturally twin turbo...not talking about a gsx or gst...
snowmobiler168
Oct 6, 2010 10:00 AM
Mitsu_effect
Feb 5, 2008 06:44 AM
Janarris
Dec 14, 2007 04:47 PM
atrix415
4th Generation
Dec 31, 2005 09:58 AM
jimmydg45
May 28, 2005 06:23 PM
