VIOLENT shaking problem
Old Mar 29, 2005 | 12:37 AM
chbidragon's Avatar
Default VIOLENT shaking problem
I have a 93 Eagle Talon, (Same as a 93 Mitubish Eclipse )
Engine: 2.0
Turbo: No
Tranny: Manual
The car vibrates VERY badly, moreso at higher speeds like 50+, and it ONLY does it when accelerating. Its so bad i cannot see out my side mirrors, or barely read my dash guages! The steering wheel does not vibrate with this...
Does ANYONE have a clue as to what it might be?? I appricate any ideas or help!
Old Mar 29, 2005 | 12:45 AM
chbidragon's Avatar
Default RE: VIOLENT shaking problem
Oh if i didn't give ya a big enough hint as to how badly the vibrating was... It broke my tranny motor mount!!! thinking that maybe it was broke before hand, i replaced it and then went for a drive again, but as soon as i got to higher speeds, the shaking started up again
Old Mar 29, 2005 | 04:17 PM
1398spdr's Avatar
suspension????? if the wheel isnt shaking, then its not the camber or alignment.......
Old Mar 29, 2005 | 06:53 PM
DSMTalonAWD51's Avatar
yea if its bad at high speeds i would say check out all alignment problems. but if it does it while accelerating maybe your motormounts are bad/loose.
Old Mar 29, 2005 | 08:41 PM
1398spdr's Avatar
yea, deff check those since the tranny mount broke loose
Old Mar 30, 2005 | 06:56 AM
sir_gyugyu's Avatar
You said that it occurs when you are accel. It is probably a bad corner stabilizer or a rubber bush in the suspension. I had it with my prior car, and replacing these solved the problem. I presume that you've had your tires checked (balance etc). Also make sure that there is no any mud, dirt pile inside your rims. Take care.
ajl44
Mar 23, 2014 10:04 AM
JansoJason
Nov 20, 2009 10:51 AM
M
Dec 15, 2005 06:31 PM
bimmer
Jul 22, 2005 05:08 AM
M
Jul 5, 2004 10:20 PM
