VIOLENT shaking problem
I have a 93 Eagle Talon, (Same as a 93 Mitubish Eclipse
Engine: 2.0
Turbo: No
Tranny: Manual
The car vibrates VERY badly, moreso at higher speeds like 50+, and it ONLY does it when accelerating. Its so bad i cannot see out my side mirrors, or barely read my dash guages! The steering wheel does not vibrate with this...
Does ANYONE have a clue as to what it might be?? I appricate any ideas or help!
) Engine: 2.0
Turbo: No
Tranny: Manual
Oh if i didn't give ya a big enough hint as to how badly the vibrating was... It broke my tranny motor mount!!! thinking that maybe it was broke before hand, i replaced it and then went for a drive again, but as soon as i got to higher speeds, the shaking started up again
You said that it occurs when you are accel. It is probably a bad corner stabilizer or a rubber bush in the suspension. I had it with my prior car, and replacing these solved the problem. I presume that you've had your tires checked (balance etc). Also make sure that there is no any mud, dirt pile inside your rims. Take care.
ajl44
Mar 23, 2014 10:04 AM
