what should i do.....
ORIGINAL: Sebba
do you feel anything in the steering wheel?
ORIGINAL: Sanguinius
What does the steering wheel have to do witht he clutch? If you have air bubbles in the resevior then you likely have a problem with the master cylinder somewhere.
haha i fixed the problem, master cylinder.......but then 5 hours after i get it back, my battery charging warning light came on, and the car is now dead........and my cooling fluid warning light is on.........damn problem after problem
Well cooling fluid warning light means you're likely low (Unless it's the temp light that's on but it's likely a low level light). Which would also indicate a leak. Have you checked the alt belt yet? That may be your charging light problem.
