Whats causing my turbo to grind when starting my car?
Old May 11, 2007 | 12:26 PM
Default RE: Whats causing my turbo to grind when starting my car?
I agree. ^
Old May 11, 2007 | 02:05 PM
50ul }{4ck3r's Avatar
well if u guys say so...THE STARTER
Old May 11, 2007 | 04:01 PM
matt02708's Avatar
My oil level is perfect I even double checked it. The oil was just changed 200 miles ago so I know that can't be it. I checked the turbo for shaft play it has VERY little play side to side. Yeah I don't hear any whine when i'm driving normal or under high boost I drive with my windows down too so I'm pretty sure I would hear it. I'll have someone start it again and put my ear by the turbo see if its really coming from it or if in fact its the starter. This p.o.s t25 won't be around much longer anyways. Thanks guys.
Old May 11, 2007 | 04:07 PM
Good u found out what it was...good luck with the car
Old May 11, 2007 | 05:04 PM
darknigh7th's Avatar
i wish i could get rid of my t25.... i'm broke lol. though when i get my 16g i'm going to make it into a lamp
Old May 11, 2007 | 05:07 PM
lol dark good idea with the lamp...i have a big 16g turbo....when i get my bigger turbo i'm making a lamp fo sho
Old May 11, 2007 | 06:14 PM
In that case then i would say its the starter.
I wasnt saying your oil level was low. What i said was that the oil pressure at idle is zero when the engine is off. That could cause the compressor wheel to rest against the housing when it sits for a while... that would explain why you dont hear it after the engine is started
Old May 11, 2007 | 10:18 PM
matt02708's Avatar
Thats a very good call. Guess i'll have to just look more into it.
pd154
May 22, 2012 01:44 AM
pd154
May 5, 2009 02:09 PM
mahicks3322
Dec 3, 2008 07:14 PM
2nejunkie
Jun 7, 2008 06:05 PM
5Tizzle
Oct 13, 2006 06:41 PM
