is it worth buying a 95 gs-t
yeah the bodys are different..but as you can see in the pic the guy changed the body to a 97-99 eclipse...
and yes i like the talon but i searched here in miami(and more up north) and they dont have what i want there non turbo..
i saw a 1995 3000gt for 5,950 and it had 96,000 miles( but it wasnt the fast one im not a genius with 3000gt so forgive me lol)
The 95 is different from the 96-99 by the front bumper and rear. Not much difference in the rear. The brake lights are in different spots. I prefer the 95's rear lights to the 96-99. As far as the front bumper i prefer the 95 over 96-99 only if the middle of the front bumper is modified by taking the "things" that make the grill and removing them then slaping an intercooler in there. Not sure if it would fit but man it would look sweet.
i called the guy and this is what he told me
he said that when you start the car it makes some weird noise but it goes away once you put the gears in...he said he has not touched the turbo...the tires are sort of new and taht the door makes a noise when you open it( he said it had nothing to do with oil that you have to change a part)
he was at work so he will call me later
so i have to see the car because it looks line from the outside but ihave to see the inside performance
Even with some minor problems like the ones he mentioned, the car is still a good deal. ****, as long as the engine runs fine after it gets warm, nothing else really matters. Short of things falling off the car lol.
Let us know what that noise sounds like. If he replaced the clutch like he said. That could be a trans. problem. Probably so considering he said when you put it in gear it stops. But getting a new/used trans isnt bad that also gives you room to talk down the price. Use that to your advantage if thats the case. Things like that are actually kinda good when buying a car. You could probably talk down enough to have money for a trans with 40-50,000 miles on it.
dam i wish i had all of this in my head like you guys...you guys know your stuff big time...i will post back when i test the car ima tear it up lol j/k i will let you guys know whats up.
