2000 gs headlights flashing
I recently purchased a 2000 Eclipse GS, and on the way home with it I noticed the passenger side headlight was not working, when I went to replace the bulb I found that the connector had melted. I replaced both bulb and connector, and afterwards, when I start the car, the bright lights flash for several minutes. If I leave the car running it will eventually stop, but it starts again if I turn the key off and back on.
So my question has several parts: 1) Any clue what is happening? 2) How can I tell if my car has a factory alarm? 3) How can I tell if I can use keyless entry with my car?
Thank you
Thank you
bugman12
01-07-2006 12:49 AM
00, 2000, 2001, alarm, blinking, blinks, eclipse, factory, flashing, galant, headlighst, headlight, headlights, mitsubishi, spyder
