2000 gs headlights flashing
Old Dec 21, 2008 | 12:07 AM
bdlrun's Avatar
Default 2000 gs headlights flashing
I recently purchased a 2000 Eclipse GS, and on the way home with it I noticed the passenger side headlight was not working, when I went to replace the bulb I found that the connector had melted. I replaced both bulb and connector, and afterwards, when I start the car, the bright lights flash for several minutes. If I leave the car running it will eventually stop, but it starts again if I turn the key off and back on.
So my question has several parts: 1) Any clue what is happening? 2) How can I tell if my car has a factory alarm? 3) How can I tell if I can use keyless entry with my car?
Thank you
Old Dec 21, 2008 | 12:39 PM
Dusty Eclipse's Avatar
Default RE: 2000 gs headlights flashing
I think the VIN can tell the stealership if it had the factory alarm/keyless...
Check the relays/fuses for the headlamps. Thats my first guess.
Chaspalm
Aug 23, 2014 05:51 PM
automasterauto
Aug 24, 2010 09:18 AM
bugman12
Jan 7, 2006 12:49 AM
yura
Aug 20, 2005 11:00 PM
Ricsta
Feb 12, 2005 10:11 AM
