engine?
Old Oct 3, 2006 | 11:23 PM
estraw's Avatar
Default engine?
just a random question, would this engine fit into my 3g? i know its the 4g64, but i wasnt sure if there was something different about it. i cant afford it now but it would be nice to know that there is something else available for the 3g since tearstone apparently no longer supplies the turbo kits
here ya go
Old Oct 3, 2006 | 11:29 PM
Default RE: engine?
Why trash your block? All you need is some nice internals and a EVO head swap and you will have basically a EVO strocker I guess you could say.
The stock block in your car is great and the stock internals are as well so beef em up and youll be safe all day. the power maxes out from the stock SOHC head so the EVO head swap has been done a few times to open up much more power
Old Oct 3, 2006 | 11:56 PM
estraw's Avatar
Default RE: engine?
how much boost can the engine take if i were to get an evo head for it, also, what year evo head would fit? thanks
Old Oct 4, 2006 | 12:33 AM
Default RE: engine?
EVO VIII or IX and I think VII as well that is what 01-06??
On the stock internals you can handle 10-15PSI with a very good tune but after internals beefed and EVO head worked a little it could take ALOT im sure.
Old Oct 4, 2006 | 01:05 AM
estraw's Avatar
Default RE: engine?
how hard is it to swap from sohc to dohc, or do you just bolt it on and go?
Old Jun 14, 2007 | 03:05 PM
loserspearl's Avatar
Default RE: engine?
So the evo 8 head really bolts on?
with the timing driver side oriented i know you can do an evo 1-3 head swap, but it dont just bolt up,you will have to freeze plug some oil holes on the 4g64 block and get 4g64 dohc gears for a galant butslowboy makes those for a good price
I'm interested because now i have the timingpassenger oriented and want to do the swap
Old Jun 14, 2007 | 03:48 PM
Dusty Eclipse's Avatar
Default RE: engine?
Seriously, this swap seems like it might be a bad idea, unless youve got a motor to throw away...
Old Jun 14, 2007 | 04:13 PM
Default RE: engine?
Nothin bad can really happen unless you blow your motor withtoo much boost
rmplstlskn
May 13, 2022 02:49 AM
Vizion
Dec 17, 2006 01:24 AM
schif_e
Jun 2, 2006 02:16 AM
m3kgt_99
Jan 31, 2006 05:25 PM
anko_kun
Jan 17, 2006 11:52 PM
