Injectors dumping fuel into cylinders!! Please HELP!!
Old Mar 24, 2018 | 01:41 PM
spyder01's Avatar
Default Injectors dumping fuel into cylinders!! Please HELP!!
Background of car: 2001 Spyder 3.0L Gt V6. Bought about a month ago. Original owner bought the car brand new. Body has 88k miles, motor and Trans were replaced with brand new and have around 15 miles, not 15k, 15. Car was afterwards built for a show car only so some components under the hood have been eliminated, but nothing that affects the running of the vehicle. It is mainly just the heat and a system.
When we went to get it, it wouldn' start. Fuel pump. Easy enough. Tore out the back seat and replaced it in no time. Ran fine but car was sitting for a very long time, so fuel was disgustingly bad. Hand pumped all old fuel out, replaced with new. Car was also throwing the p0300 code, multiple misfire. So went through the process of replacing everything dealing with that (plugs, wires, coil pack etc). Also bought refurb fuel injectors (tried to save money). Started up fine, then noticed the injectors were just dumping fuel into the cylinders. So went online and bought BRAND NEW not refurb injectors. Went through all that again on swapping those out. It starts up fine like normal. Give it about 30 seconds to a minute and the injectors again are dumping fuel. It is also still throwing the p0300 code. I tried searching online for causes and am only finding issues related to fuel injected cars flooding on start and shutting off and not starting again. Any and all info is greatly appreciated!!
Old May 14, 2023 | 06:46 AM
03_Spyder-GT's Avatar
Cool Injectors dumping fuel into cylinders!! Please HELP!!
[I'm having the same problem change the fuel pump and timing belt and it keeps washing out my plugs Ii can take the fuel pump relay out and spray starting fluid into a vacuumed hose and starts right up till it runs outta combustable liquid put the relay back floods it agian makes no since at all appreciate some feed back if anyone figured out a solution
Last edited by 03_Spyder-GT; May 14, 2023 at 06:49 AM. Reason: Couldn't read it cause of the original post
Souhradaj360
Nov 7, 2019 04:33 PM
2001Mitch3.5XS
Mar 15, 2018 04:09 PM
xDread92x
Feb 6, 2017 11:15 AM
jimbo
Dec 6, 2008 05:51 PM
poiz
Oct 17, 2005 07:30 PM
