My eclipse keeps overheating ?!
Old Dec 2, 2013 | 02:11 PM
des85's Avatar
Default My eclipse keeps overheating ?!
Hi guys!
So i'm just a girl that don't know much about cars, but been having some issues with my eclipse spider gs 2001, it has 117 000 milage on it.
Its been running good, until one day a few month ago it overheated. I took it in and they saw a hose was leaking,so they fixed that filled it up, burped it and put a new cap on the radiator. It worked for another week, until it overheated again, took it to a another shop and they tested it negative for a head gasket leak, but found that the thermostat was bad and actually didn't open so changed that.
The car worked fine for about 3 weeks and now the problem is back, Last night I got stuck in some heavy traffic and couldn't move, the temp went up in the red zone, but as soon as i pressed the gas and start coming up in speed 20mpg it went back in a second to about 45%.
Its only overheating when stopped in traffic and or in idle.
Today I drove it on the freeway for about 10 minutes, temp was about 45%. Drove some minutes in some stop and go traffic and seeing the temp is going up to about 50% … when I parked the car and let it run, the temp was about 45%, opened the hood, the fans were spinning, the coolant level is almost up to full, after a few minutes the fan went on really hard and I felt on the hose and the lower one and it was not so hot, i could grab them for a while. Looked back in the car and the temp sensor is almost up in the red zone. No a/c was on, fan working and it comes out cold air and hoses are not that hot.
What can be the problem?
I'm so tired of spending days at the mechanics
Old Dec 2, 2013 | 04:02 PM
mxmikie's Avatar
sounds like a plugged radiator
Old Dec 8, 2013 | 04:50 AM
Biskitking's Avatar
My suggestion is to have the radiator flushed, you can buy a kit and do it yourself, but also, the water pump, might have worn itself out pushing against a faulty thermostat. That is the last two major things that control cooling, so Id start there.
litildevil75
May 2, 2016 07:25 AM
MrNeil1974
Apr 16, 2014 08:47 AM
monsterbishi
Jun 6, 2013 07:18 PM
vossroad
Nov 23, 2010 08:52 PM
zeanimal2001
1st Generation
Aug 11, 2007 11:53 AM
