Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
aux jack installation
Old Jan 6, 2005 | 06:57 PM
jwmeara's Avatar
Default aux jack installation
I have a 2001 Eclipse w/ Infinity / 4 disk changer. I'm putting in Sirus/ Blaupunkt receiver and would like to use an aux jack instead of the wireless modulator. Does anyone know how to install an aux jack with the factory receiver?
Old Jan 18, 2005 | 01:29 AM
customizedrides's Avatar
Default RE: aux jack installation
What you have to do is go to a local audio dealer and ask them for what is called a PIE adapter. What that will do is plug into your factory deck where your changer goes and adapt the other end to match your reciever. Unfortunatly you will loose the changer in this process. If no where local has it, call Best Buy and they can give you a web page to order it. should be around $30
Old Jan 18, 2005 | 11:04 AM
jwmeara's Avatar
Thanks for the info, wish there was a better way though...........
Old Jan 23, 2005 | 03:48 AM
The only other way is the FM modulator unfortunatly. The only thing to better that situation is get a good one that plugs in and doesn't run off batteries. GOOD LUCK
alsaaron
16
Mar 27, 2020 09:19 AM
Ckmann
Jun 28, 2016 10:25 PM
alsaaron
Oct 3, 2014 10:34 AM
ezekiel044
Sep 17, 2009 01:55 PM
