1996 420A Eclipse - Valve Cover Gasket Replacement
Old Oct 11, 2011 | 04:53 PM
dopeysw20's Avatar
Default 1996 420A Eclipse - Valve Cover Gasket Replacement
Hi! I'm planning to replace the valve cover gasket and spark plug chamber seals for my eclipse due to massive oil leakage. I've never done this before, and wanted to confirm whether I should be using any silicon for additional sealing. I've been reading various blogs and forums (including the eclipse bible) and have been getting mixed instructions whether or not to use silicon. Any advice would be much appreciated! Thanks!
Old Oct 12, 2011 | 09:06 PM
_93TSI_370+K_'s Avatar
Default Use good gasket set and torque to specs
Use the OEM or a good aftermarket gasket like Fel-Pro, torque the cover to specs, you should be good to go without any additional RTV silicone.
lerch20
Jun 18, 2013 08:49 PM
mrvivona
Jun 12, 2011 12:08 PM
bcolins
15
Mar 31, 2010 11:55 AM
Roberte
Aug 22, 2008 07:38 PM
mdoc111
Apr 5, 2007 10:51 PM
