1999 Diamante - charging issue
Old Jun 19, 2012 | 11:47 AM
s4bill's Avatar
Default 1999 Diamante - charging issue
The car has a new battery (3 months old).
The battery light start coming on a about a week ago. It would come on and then go off.
The battery died. If you hot shot the car it would start but would not run long.
I charged the battery and was able to get it home.
Once I got home I did the ohm meter test but the battery was a little on the low side so I didnt trust the test but I did it anyway and the alternator test failed.
I re-charged the battery and re-did the test. The test showed the volts increase above 12 volts as you expected. So I asked my daughter if the battery light was gone and it wasn't so I shut off the car and shook my head
So I re-started the car and re-did the test and it failed the test.
So it seems that I have an intermettent problem. No mattter what I did, I could not get the ohm meter to go back over 12 volts like it did the one time.
I pulled the alternator (that was fun!) and took it to Advance auto for a test and the test showed it as good.
Any idea what could cause this?
tolstein
Oct 12, 2014 08:43 PM
Buddinator
May 14, 2011 08:21 AM
tjbiker031
Aug 23, 2009 04:59 PM
jvsutton
19
Apr 13, 2009 01:26 PM
92RS
Apr 15, 2005 10:00 AM
