1999 Eclipse rs p0303 cylinder 3 misfire
Old 04-16-2010 | 11:58 PM
Asalsbury11's Avatar
Default 1999 Eclipse rs p0303 cylinder 3 misfire
i just bought my eclipse a few days ago and after driving it a while the check engine light has come on with a cylinder 3 misfire it starts very rough and seems like it will idle but as soon as you let out the clutch it wants to stall i looked all over the internet but couldnt find any specific fix for it any help would be great Thank you
Old 04-17-2010 | 01:44 PM
sounds like bad plug wires to me
Old 04-18-2010 | 10:23 AM
all the wires were new ,thats what i thought it was at first also so we did a compression test and found that cylinder 1 was at 150 psi 2 was at 120 3 was 60 and 4 145. so i think we are going to have to pull the head apart and rebuild it? what do you think?
Old 04-19-2010 | 08:59 AM
woa 60!!!
yea that sounds like a bad valve then
Old 04-20-2010 | 06:20 AM
yeah we got an engine guy looking at the head he said it looks like it was over heating and strong feeling i have to replace a few valves
Old 04-20-2010 | 07:19 AM
yea that is what i would suspect to. So your gonna want to replace the timing belt, tensioner, water pump, head gasket, valve stem seals, valve cover gasket at least. There may be some stuff im missing but those are the important stuff while you are in there
Old 04-21-2010 | 06:20 AM
yep there were 3 bad valves and i should be getting the head back today all the piston rings look like they arent an issue so im hoping my troubles stop here
Airmed802
02-02-2015 08:01 AM
2003EclipseRS
10-18-2011 02:57 PM
dcvee
33
08-08-2007 06:41 PM
ck76
07-23-2007 11:13 PM
signtist2004
10-19-2006 11:01 AM
Quick Reply: 1999 Eclipse rs p0303 cylinder 3 misfire
