1999 Eclipse rs p0303 cylinder 3 misfire
Old Apr 16, 2010 | 11:58 PM
Asalsbury11's Avatar
Default 1999 Eclipse rs p0303 cylinder 3 misfire
i just bought my eclipse a few days ago and after driving it a while the check engine light has come on with a cylinder 3 misfire it starts very rough and seems like it will idle but as soon as you let out the clutch it wants to stall i looked all over the internet but couldnt find any specific fix for it any help would be great Thank you
Old Apr 17, 2010 | 01:44 PM
sounds like bad plug wires to me
Old Apr 18, 2010 | 10:23 AM
all the wires were new ,thats what i thought it was at first also so we did a compression test and found that cylinder 1 was at 150 psi 2 was at 120 3 was 60 and 4 145. so i think we are going to have to pull the head apart and rebuild it? what do you think?
Old Apr 19, 2010 | 08:59 AM
woa 60!!!
yea that sounds like a bad valve then
Old Apr 20, 2010 | 06:20 AM
yeah we got an engine guy looking at the head he said it looks like it was over heating and strong feeling i have to replace a few valves
Old Apr 20, 2010 | 07:19 AM
yea that is what i would suspect to. So your gonna want to replace the timing belt, tensioner, water pump, head gasket, valve stem seals, valve cover gasket at least. There may be some stuff im missing but those are the important stuff while you are in there
Old Apr 21, 2010 | 06:20 AM
yep there were 3 bad valves and i should be getting the head back today all the piston rings look like they arent an issue so im hoping my troubles stop here
Airmed802
Feb 2, 2015 08:01 AM
2003EclipseRS
Oct 18, 2011 02:57 PM
dcvee
33
Aug 8, 2007 06:41 PM
ck76
Jul 23, 2007 11:13 PM
signtist2004
Oct 19, 2006 11:01 AM
