2001 eclipes heating problum
Old Dec 13, 2008 | 12:19 PM
Davids's Avatar
Default 2001 eclipes heating problum
The heater in my 2001 eclipes works ok when RPMs are up, but at an idel it cools right down. I just replaced the thermostat. that mad no differance. Does anyone have a suggestion were to go next.
Old Dec 13, 2008 | 12:51 PM
dsm1990gsx's Avatar
Default RE: 2001 eclipes heating problum
How many miles are on the car and what did the coolant look like when you changed the thermostat?
Old Dec 13, 2008 | 01:53 PM
Davids's Avatar
THe car has 125,000 miles on it. The coolant looked fine.
Old Dec 14, 2008 | 08:25 AM
Manybrews's Avatar
the only thing that could cause that issue is a low coolant level, or a giant air pocket.
Old Dec 14, 2008 | 09:59 AM
dsm1990gsx's Avatar
ORIGINAL: Manybrews
I was thinking the same thing, or possible flow problem.
Old Dec 14, 2008 | 10:51 AM
Davids's Avatar
I will try perging the system of air. Would'nt you thing I would have over heating problums if there was a flow issue.
Old Dec 14, 2008 | 11:12 AM
dsm1990gsx's Avatar
If the heater core is partially blocked it would give you issues at idle since the coolant isnt flowing as much as it would be if you were cruising at abt 3-4k rpms. Check the heater hoses that go to the heater core and see if there are hot to the touch.
Old Dec 15, 2008 | 12:35 AM
Dusty Eclipse's Avatar
Out of curiosity, you ever get any liquid under the dash on the passenger side?
Old Dec 15, 2008 | 07:21 AM
Davids's Avatar
No water under dash. I did check heater hoses, passenger side is hot the driver side is luke warm. I guess it looks like a heater core is in the near future.Any advise on this. I just did the one in my 2003 Dodge Ram. I had to remove the dash to get at that one, I am asuming this will be the same in this case.
NissanR34
Aug 27, 2012 06:44 PM
mcam
Jun 5, 2011 04:07 PM
ansar
Jun 1, 2011 09:19 PM
Dmax6.6
Mar 19, 2007 01:30 PM
jake88
Oct 16, 2006 10:21 AM
