2001 Galant leaking water onto passender floorboard! HELP!
Old Aug 15, 2009 | 04:23 PM
cindys's Avatar
Default 2001 Galant leaking water onto passender floorboard! HELP!
hey guys, I have done a little research on here and cant find the answer.
my wifes car is leaking water onto passenger floorboard and has really saturated it in the past week. I got under there and removed the first thin plastic panel and it had accumulated alot of water. I notice that it is the AC unit under there and assume that the prob is related to such. The AC works perfectly. Also to note is that there is a weird sound coming from that area upon hard left turns and sounds as if freeon is leaking or something. as i attempted to remove another piece of the AC, it starting raining hard outside so i decided to jump on this forum for answers. anyone have this problem? any solutions? Thanks everyone John
Old Aug 16, 2009 | 07:29 PM
cindys's Avatar
Default help
bump! anyone out there know galant ac system/ im assuming its a clogged line and i was told today that when she took a hard left, a big squirt of water shot down onto floorboard. help.
Old Aug 18, 2009 | 04:05 PM
cindys's Avatar
no one really? since its not draining onto pavementr under car im guessing its a clogged line somewhere. but where? anyone?
Old Aug 21, 2009 | 01:57 PM
airplanedoc's Avatar
Cool Same problem
I had the same problem in my 2003 Galant, turned out the drain line from the heater core area under the dash was clogged and full of water hence overflowing onto the passenger floor take most of the dash apart to get in there and unclog with compressed air and a coat hangar.
Old Sep 3, 2009 | 12:36 AM
bumpn's Avatar
yes i strongly agree on the last post! usually when you have a heater core problem it usually dripps inside the vehicle... are u positive it is just water and not antifreeze?
whitey86
Sep 7, 2014 11:44 PM
3130
Jun 8, 2013 05:57 PM
SpyderDave
Dec 6, 2011 09:02 AM
Kptaylor
Jul 28, 2011 02:17 AM
mysterio2099
Feb 27, 2006 02:27 PM
