3000gt timing
Old Nov 8, 2005 | 10:00 PM
kaos8704's Avatar
Default 3000gt timing
94 non turbo dohc 3000gt i replaced ther timing belt. i got ahead of myelf and cannot find a book or nethign to find otu how to put the cams back how there supposed to be. any help would be great
thanks
Old Nov 8, 2005 | 10:23 PM
Joel_CA's Avatar
Default RE: 3000gt timing
There are arrow marks on the valve cover that need to match up with the line notches on each cam gear. The crank sprocket itself should have a mark that lines up with an arrow on the oil pump case. Before starting, remove the hydraulic tensioner and reset it with a bench vice- once you push the rod back in, use a heavy pin to hold it in place through the hole. (Hopefully, you removed the timing belt with the engine is sitting on #1 TDC .) I suggest you start at the crank, working your way COUNTER CLOCKWISE through each cam gear pulling all the slack too. Once you wrap it around the cam gear, it will help if you pinch it down with a metal paper clip against the cam gear teeth. Be absolutely careful and be sure that it is timed PERFECTLY as there is very little room for error on this interference engine.
Joel, CA
marshmallow746
Jun 10, 2022 10:20 PM
judien
Mar 9, 2018 03:41 PM
sherk
Mar 5, 2013 10:47 AM
8000RPMS
Aug 30, 2007 05:49 AM
bigguy6f4
1st Generation
Jul 9, 2007 05:45 PM
