'96 Eclipse Clutch Losing Pressure
Old Mar 1, 2010 | 08:22 AM
mon3y0's Avatar
Exclamation '96 Eclipse Clutch Losing Pressure
My 1996 eclipse RS loses pressure on the clutch. the car wouldnt go into gear and then i bled the clutch yesterday. after bleeding the clutch it worked fine, but when i got in the car this morning i had to pump the clutch pedal several times to build the pressure back up. now i have to pump the clutch at every redlight or stop sign. its really annoying. can someone please tell me whats wrong.. i parked the car overnight on concrete pavement and there were no signs of leaks on the concrete the next morning.
Old Mar 1, 2010 | 09:14 AM
sounds to me like a bad master cylinder or slave cylinder.
Old Mar 4, 2010 | 09:20 PM
MitsMaster's Avatar
If you M'cyl is leaking look under the dash at the firewall. Right where the rod runs through you will see fluid running down the firewall to the floorboard. The M'cyl could just be bypassing also.
wild-wood
Jun 3, 2021 07:38 PM
Holly
1st Generation
Oct 19, 2010 07:46 PM
GalantRacer06
Dec 28, 2005 04:33 PM
Atownprepy99
Sep 11, 2005 03:34 AM
FZ1speed
Aug 31, 2005 04:16 AM
