'98 Eclipse cooling fan
Old Mar 5, 2010 | 01:52 PM
gainco's Avatar
Default '98 Eclipse cooling fan
My daughter has a '98 Eclipse 2L no turbo and I noticed that the right rad. cooling fan wasn't running while the left one was. Does anyone know if the fans are electrically in parallel, or is each fan controlled from a different temp. switch? I found no voltage on the connector- I noticed 4 wires on the right motor connector and 2 on the left connector- what are the extra 2 leads for on the right connector?
Old Mar 11, 2010 | 10:34 PM
MitsMaster's Avatar
Both fans should come on with the a/c on. If the a/c is off the other fan should come on if the engine is near overheating. And they also may have a high and low speed controled by the ecm.
Old Mar 12, 2010 | 11:12 AM
gainco's Avatar
Thank you for the response. Good idea- I will turn the a.c. on and see if both fans kick in.
firstsuv
Oct 19, 2012 09:47 PM
billscarver
Jul 1, 2011 03:24 PM
dj_jerry_p
Mar 10, 2010 08:42 PM
hara_ca
May 25, 2007 08:09 PM
shildog
Feb 5, 2007 09:07 PM
