auto to 5 speed tranny swap
Old Jun 14, 2010 | 01:31 AM
eclipselaxr18's Avatar
Default auto to 5 speed tranny swap
i wanna do a transmission swap to a 5 speed manual in my 99 eclipse and what all will i need to do the swap and i mean everything plz help me with this the sooner i get the info on what i need the sooner i get everything i may need to put the tranny in
Old Jun 14, 2010 | 03:54 PM
you need a donor car....plain and simple. There are alot of parts that are required. Here is a 1g but the basic approach is the same with the parts required
http://www.vfaq.com/mods/wayback/autotomanual.html
Old Jun 16, 2010 | 11:24 PM
the car im getting the parts from is a 97 eclipse and my car is a 99 will i have any issues with the ecus or should i try and find a 99 manual ecu
Old Jun 17, 2010 | 10:40 AM
no you should be fine with the ecu from the 97.
Old Jun 17, 2010 | 12:46 PM
ok good deal and also how do i get the clutch and flywheel off i dont c an way to un bolt it all the bolts on the clutch are rounded studs and not bolts
Old Oct 7, 2010 | 11:41 PM
greengoblin2010's Avatar
sounds like a modular unit. what that means is all the clutch parts are pre installed together from the manufacturer and go in and out as one solid piece. should just be able to slide the whole unit out off the spline.
Linoone
Feb 19, 2011 02:31 PM
importorigins
Sep 20, 2009 10:33 AM
max3
Jul 21, 2007 04:46 AM
2slow
1st Generation
16
Jun 18, 2007 09:06 PM
MiataDooU
Nov 19, 2003 03:27 AM
