braking problems
Old Jun 20, 2007 | 11:44 AM
rses's Avatar
Default braking problems
i owe an 02 Mitsubishi Lancer ES and i'm having problems w/ my brakes.
when i gently hit the brake i hear grinding noise and i can feel the car vibrate whenever i brake.
i took it to Midas and they said the brake pads are still%60 good.
could it be the rotor? can anyone help out?
this problem been happening for months now...
Old Jun 20, 2007 | 12:11 PM
Default RE: braking problems
Your rotors are warped. You need to heat cycle new rotors before using them normally.
Replace them with either factory rotors or get some brembo rotors that will never warp. If you are going to replace them with factory ones, take the car upto 100mph (or what ever you have the ***** to do)and brake down to 70... and repeat this over and over. Just remember, being on the brakes for a split second is what warps them. It causes them to be un evenly heated.
Old Jun 20, 2007 | 01:25 PM
rses's Avatar
what does it do by hitting the brake up to 70? does it increase the noise and the vibration?
jp2000
Jan 1, 2012 05:21 PM
glttrybuttrfly
Aug 18, 2005 11:18 AM
95EclipGS
Aug 9, 2005 09:24 PM
rx7reality
Oct 14, 2004 07:45 AM
deadweasel101
Jul 6, 2004 03:02 PM
