how do i change my front main seal?
Old Mar 6, 2006 | 10:45 PM
bigchief2472000's Avatar
Default how do i change my front main seal?
i let some mechanic put a new water pump on my 95 3000gt and ever since then ive had an oil leak, like a quart evry 2 days. ive been tryin to figure out where it was comin from so i cleaned the engine up and took it around the block then checked it out and it looked to me like it was comin from the water pump so i took it back to the guy and he said it was probably the front main seal but i dont wanna let him work on it anymore so if ya know anything about changin these out let me know.
Old Mar 9, 2006 | 11:37 PM
Joel_CA's Avatar
Default RE: how do i change my front main seal?
The front seals should have been replaced the same time your H20 pump was replaced. To replace it, you'll need to remove the timing belt that was removed when they replaced your H20 pump.
Joel, CA
Old Mar 12, 2006 | 09:26 AM
yea i figured that and i already know thats a pain in the *** but where exactly is the seal at....the water pump, oil pump, or around the crankshaft? i have no idea
Old Mar 12, 2006 | 01:30 PM
Joel_CA's Avatar
The seal you're looking for is around the front of the crank. Since you'll have everything apart, you should at least insect all of the other seals around the cams and replace them. Good Luck!
Joel, CA
Old Mar 12, 2006 | 04:59 PM
thats a pretty good idea cuz i definately dont wanna be takin it back apart anytime soon. thx for the advice
Dave Braun
Feb 22, 2012 03:14 PM
CT67GTX
Jan 6, 2008 01:24 PM
matthew_m75
Aug 8, 2007 11:06 PM
gst4me
Feb 5, 2007 12:33 AM
xxkels
Nov 23, 2004 02:30 AM
