IAC changed now idles high
Old Feb 15, 2014 | 10:28 AM
fireman53d's Avatar
Default IAC changed now idles high
I had a bad IAC(idle air control valve) that I replaced due to my car no longer would idle when cold. The new one solved that problem.
Now, however my car idles wayy high about 1500 rpm when cold then 1200 when warmed up. I tried to adjust the idle down on the throttle body but the screw is to its lowest setting.
How do I correct the high idle now???
Thanks
Old Feb 15, 2014 | 12:09 PM
Akzle's Avatar
was it the right iac?
Sounds like youre getting more air through...
Old Feb 15, 2014 | 02:48 PM
fireman53d's Avatar
I reset the ecm and after starting the car it idles high then works its way down to normal. Turning on the A/C increases the rpm's but then it stabilizes. I think it will be fine and the ecm just needs to adjust to the new IAC.
Old Feb 16, 2014 | 08:07 AM
mxmikie's Avatar
change your temp sensor and you can adjust the IAC with an allen wrench
Old Feb 16, 2014 | 08:11 AM
fireman53d's Avatar
Which temp sensor and why do you say that I need to? I didnt see anywhere on the iac for an allen wrench to adjust.
dart6
Feb 16, 2011 09:25 AM
batholith
Jan 16, 2010 12:56 PM
raycam2kx
Aug 16, 2007 08:33 PM
Quick93gsx
Jul 7, 2007 05:16 PM
dsfii
May 10, 2005 03:08 PM
