Size of bolt for AC belt tensioner 4G64 2.4
1997 Eclipse Spyder GS 4G64 2.4L
I recently put in a new water pump, balance shaft belt and timing belt a well as changing the 3 drive belts. After I tensioned the AC compressor belt I backed off a bit on the bolt that pushes against the bracket to tighten the tension up. (I hope that was the only mistake I made -- all else seems fine) After going for a test drive, I double checked everything and went to retighten the belts and the bolt had vibrated out and was gone.
Does anyone know the size of the bolt? I picked up 2 at Lowes, but they weren't metric and neither (surprise!) has the correct threads. If it won't thread in by hand, I never force it.
Thanks for any replies!
wayno100
11-12-2010 09:20 AM
corsair_105
08-23-2009 03:19 PM
ultramindbrk
01-09-2007 02:20 PM
rvrexpy
01-31-2005 03:33 PM
1997, 93, 97, ac, belt, bolt, compressor, dsm, eclipse, gs, mitsubishi, spyder, syder, tensioner, tightening
