Size of bolt for AC belt tensioner 4G64 2.4
Old Apr 23, 2012 | 12:11 PM
trainfun's Avatar
Default Size of bolt for AC belt tensioner 4G64 2.4
1997 Eclipse Spyder GS 4G64 2.4L
I recently put in a new water pump, balance shaft belt and timing belt a well as changing the 3 drive belts. After I tensioned the AC compressor belt I backed off a bit on the bolt that pushes against the bracket to tighten the tension up. (I hope that was the only mistake I made -- all else seems fine) After going for a test drive, I double checked everything and went to retighten the belts and the bolt had vibrated out and was gone.
Does anyone know the size of the bolt? I picked up 2 at Lowes, but they weren't metric and neither (surprise!) has the correct threads. If it won't thread in by hand, I never force it.
Thanks for any replies!
ultramindbrk
Jan 26, 2025 08:47 PM
wayno100
Nov 12, 2010 09:20 AM
corsair_105
Aug 23, 2009 03:19 PM
Christyjohn
Mar 11, 2007 01:37 AM
rvrexpy
Jan 31, 2005 03:33 PM
