Stalling after installing new battery, alt, and belts
Old Apr 24, 2006 | 10:34 AM
embassy17's Avatar
Default Stalling after installing new battery, alt, and belts
Since my 99 Galant(2.4L) has 100k, I decided to be proactive and install
a new alternator, battery, and belts. The car was working fine before I
installed everything. After installing everything, now it stalls every now
and again w/o any consistency. I removed the alt and battery, took them
to Autozone, had them tested, and they were both ok. I put them back in
and I still have the same problem. Help
Could my belts be too loose or too tight?? Bad wiring between the alt and battery. I'm just
a weekend repair type of person so any assistance would be appreciated.
Thanks!!
Mike C.
Old Apr 24, 2006 | 03:20 PM
Default RE: Stalling after installing new battery, alt, and belts
Check your alt and battery. The new alt could have a problem. What guage wire was used?
Old Apr 24, 2006 | 03:48 PM
Loose battery terminals will do that.
Old Apr 24, 2006 | 04:00 PM
I doubt that though. If he is able to start up ok.
Old Apr 24, 2006 | 05:31 PM
embassy17's Avatar
I wish it was loose battery terminals I even cleaned the darn things off.
Another website told me that it may be my computer trying to reset.
Old Apr 24, 2006 | 05:51 PM
that could be... dissconnect it and pump the ABS and leave it to drain of power. Recommect it and start it up... it may stall instantly... keep it alive with the throttle and go for a drive. It should be fine after a few miles.
Old Apr 24, 2006 | 06:06 PM
ORIGINAL: Sebba
TheENgineers Talon would run fine for a little while and then die out at a stop or something and it ended up being a loose terminal
Old Apr 24, 2006 | 06:14 PM
Well he has checked them all and its not em. I say you could have gotten a bad alt.
monkeyman
Jan 22, 2013 06:36 PM
hoss
Sep 2, 2007 11:30 AM
flunnky
Feb 18, 2007 02:25 AM
Frost89
Jan 11, 2007 01:35 AM
DanD
Aug 30, 2006 01:04 PM
