Starting Problem
Old Jun 23, 2022 | 09:15 PM
Lester Patrick's Avatar
Default Starting Problem
Hi Everyone!
I am having an intermittent problem with starting my Mitsubishi Diamante 2002 LE. It hesitates sometimes when I turn the key. It would be like when your battery is weak or dying, but I've changed the battery, and when it didn't correct the problem I tried another. So, it's not the battery. I've also tried several starters. I had to change the starter and that's when the problem started. Before I could try another starter, the new one malfunctioned and so I had to change it anyway, but the problem still persists. Someone suggested that it could be a bad ground to the battery. So, that cable was changed and the problem still persists. Has anybody had a similar problem, and how did you fix it? Thank you for the help!
Captnkitty
May 9, 2018 09:51 AM
Kevoz
Dec 2, 2008 09:14 PM
Mike Kelley
Jan 14, 2008 05:53 PM
19eclipse91
Aug 26, 2006 03:56 PM
MitsubishiBabe8
Sep 27, 2003 01:03 AM
