starting problems
Old Nov 14, 2005 | 01:59 AM
cagiestbat's Avatar
Default starting problems
I have a 95 GS model. I am having problems with the car cranking all the time. sometimes i go into the store come back out and it won't start. then i wait a few minutes, sometimes maybe up to 40 mins. then it start. it sounds like it is not getting any fuel but I have replaced the fuel pump, fuel pump relay. the mechanics are baffled too. just can't figure out what is going on. the injectors are firing and the fuel line is clean. can someone give me some help on what is causing this. other than this problem, the car checked out fine.
Old Nov 14, 2005 | 09:45 AM
Sanguinius's Avatar
Default RE: starting problems
Have you checked fuel pressure? Also have you checked for a possible short in the fuel pump/injector wiring? Also check the spark plugs for fire?
Old Nov 14, 2005 | 05:13 PM
edaddik's Avatar
it could be some electrical problem. have your car check with a OBD reader that is he smartest way on finding what's wrong in your car.
jp2000
Jan 1, 2012 05:21 PM
kainrath
Aug 21, 2006 06:11 PM
Sparky63
Jul 19, 2006 06:23 AM
emssniper
1st Generation
Mar 13, 2006 11:51 PM
Parker
Sep 23, 2003 01:27 PM
