Sunroof help!!
Old Apr 24, 2008 | 08:23 AM
lilboy1023's Avatar
Default Sunroof help!!
I need some help with my sunroof please. I tried to search on a similar problem, but mine is a little different than the others I found. I just bought this 1997 Eclipse GS 5 speed manual. It needs some work but my problem I need help with is the sunroof won't open. I am not getting any power to the switch. Where is the relay, or is there one, for the sunroof. I looked in the engine and saw a sopt for a relay labeled TOP, but there wasn't any pins sticking up from the bottom like there should be a relay there. Is there another place, or piggy backed off another one, that I should look for? I am pretty good all around with mechanics, just need a direction to look. Thanks for all your help.
Old Apr 24, 2008 | 03:45 PM
dsm1990gsx's Avatar
Default RE: Sunroof help!!
Here is a pic of the sunroof wiring diagram, since you dont have power at the switch, check to see if you have power at the sunroof ecu.
Old Apr 27, 2008 | 11:23 AM
lilboy1023's Avatar
Thanks for the help. I will check it out and post what I found. It will be a week or so till I get back from my off road trip.
Old May 13, 2008 | 09:05 PM
lilboy1023's Avatar
Thanks again for the help. It worked, found a bad slot in the fuse panel. New fuse and repaired the panel and it worked. Now a new problem. It goes back and forth but won't come down when all the way forward. it goes to a point and these"feet" stay in place and the track goes all the way forward. I have to push the "feet" forward and the glass drops down. It leaks because it doesn't seal. I am thinking I need a new track. What do you guys think? Thanks for the help. Here are a couple pics for you to guide your help.
[IMG]local://upfiles/16787/879C4A66D642423EA2323688C0A2CBB7.jpg[/IMG]
[IMG]local://upfiles/16787/89E1E36FE05544999FB64528BD1B16EB.jpg[/IMG]
jthorn75
Jun 4, 2012 04:18 PM
MrJayDeeOne
Aug 23, 2007 03:58 AM
98_GstEclipse
Sep 14, 2006 01:40 AM
SPECOPS
Jan 31, 2006 11:49 AM
iceyman
Nov 2, 2003 06:26 PM
