timing belt replacement
Old Jun 8, 2007 | 09:57 AM
outtatime's Avatar
Default timing belt replacement
I have a 1999 eclipse with the 2.0 four cylinder. car has over 80,000 miles. I changed the timing belt and now can't keep the car running. I aligned the cam and crank, reassembled the car and it ran great for about 3 miles ,,, then it starts chugging and clattering ,,, no power. go back into timing cover and timing marks are out of alignment. re-align ,, re-assemble ,, and same result. runs fine at first ,, but soon starts running poorlyand thenhardly runs at all. dis-assemble to find timing marks out of alignment again. What am doing wrong? Is there a certain step or procedure i am missing?
Old Jun 8, 2007 | 10:28 AM
Dusty Eclipse's Avatar
Default RE: timing belt replacement
Is it tight? Maybe the tensioner is bad?
Old Jun 8, 2007 | 11:33 AM
outtatime's Avatar
tensioner seems good ,,, belt is tight.
If I align the marks and manually turn the engine until no.1 cylinder comes back to TDC,,
Old Jun 8, 2007 | 05:13 PM
Manybrews's Avatar
the timing is obviously off. or you managed to bend a valve during the installation process.
im assuming you're talking about the turbo engine?
Old Jun 11, 2007 | 12:38 PM
outtatime's Avatar
nonturbo (420A I think)
I've been told that it's the 2.0 non-turbo with 205hp. I don't know if that's true or not. (Anniversary OZ sports packageversion).
Old Jun 11, 2007 | 01:40 PM
you must be aligning them wrong. How are you aligning them?
Old Jun 11, 2007 | 04:23 PM
Manybrews's Avatar
yes, you have the timing off. it IS an interference engine, so lets hope you havent damaged valves or pistons.
and the 420a engine produces 140 HP.
Old Jun 12, 2007 | 01:49 AM
I Drive Naked's Avatar
Oh man...
When you did the belt, did you change the timing belt Tensioner and idler pulleys?
I had a co worker with a 420A who did'nt and had the same issue, it kept jumping time by one or 2 teeth, then the old tensioner exploded and destroyed the head.
If its not too late, I would change the idler and tensioner, check the valves, and go from there.
Old Jun 12, 2007 | 05:55 AM
Kaede.Noir's Avatar
Is it posible to check if a valve is bent or broken with a vacuum gauge in those few seconds of the engine running? thatd help determine the problem if possible
Old Jun 12, 2007 | 11:36 AM
Like Josh said, I still think its the tensioner. The OZ anniversary edition, came with a 420a w/ 140hp as Manybrews said... its really a GS with a Sticker and wheel pkg.
galanturd
Mar 24, 2005 02:52 AM
speedform
Feb 25, 2005 09:00 PM
osu girl
Jan 11, 2005 03:33 PM
avachell
Sep 30, 2004 03:29 PM
cookiefan
Feb 25, 2004 11:36 AM
