Timing Question
Old Feb 16, 2008 | 09:49 PM
hiflyen's Avatar
Default Timing Question
I am currently finishing an hoverhaul and have a question about the timing. The book tells you to set the crank at half a tooth counter clockwise. Is this so that you will end up with all of the timing marks matching when the belt is tightened or should the crank still be half a tooth counter clockwise of tdc??
Old Feb 17, 2008 | 12:13 AM
itsme71190's Avatar
Default RE: Timing Question
have the #1 piston at tdc. crankshaft at 1/2 tooth retarded. once the pin is pulled from tensioner everything will b lined up. turn the crank manually and listen for any ticks or clicks. check ur timing multiple times!! dont wanna mess up a motor even tho 1 tooth wont kill. just will run this ****
Old Feb 17, 2008 | 12:56 AM
hiflyen's Avatar
thank you so much!
marshmallow746
Jun 10, 2022 10:20 PM
judien
Mar 9, 2018 03:41 PM
sherk
Mar 5, 2013 10:47 AM
8000RPMS
Aug 30, 2007 05:49 AM
bigguy6f4
1st Generation
Jul 9, 2007 05:45 PM
