torque converter/flywheel problem
Old Oct 11, 2005 | 11:58 AM
ajsdad's Avatar
Default torque converter/flywheel problem
i have a 1994 diamante(beautiful car) but i had a new converter/flywheel installed and when you start the car it grinds real bad, the starter is only catching a small portion of the flywheel.(the converter/flywheel are made together)does anyone have an idea of what we can do to solve this problem?we have tried 2 con/fly assembles, and a new starter form mitsubushi and we STILL have this problem, can anyone help me............thanks jerry
Old Oct 11, 2005 | 08:27 PM
Lil red's Avatar
Default RE: torque converter/flywheel problem
How little is it catching? Is it like its just barly touching the teeth and rounding then off or is it only touching halve of the tooth from side to side? Who is installing these parts? Have they ever done this before? Not trying to offend anyone but i know sometimes it can be hard to line up the starter just right. Expecially if you have no help.
Old Oct 11, 2005 | 09:03 PM
Patrick's Avatar
Administrator
hmm..it definately sounds like either the installation is wrong, or you have something bent/misaligned which is causing the flywheel to not make good contact with the starter. has the car been wrecked or anything? and are you using OEM parts?
CanadianOutlander
Dec 5, 2007 02:05 PM
sk8dudety
Nov 12, 2007 10:37 AM
badbowtie73
Jun 20, 2007 05:57 PM
UCYIBD1
Dec 4, 2006 10:57 AM
iceman
Jan 24, 2006 12:13 PM
