Transmission problem, automatic has no reverse or OD
Old Oct 16, 2008 | 03:01 PM
superpete69's Avatar
Default Transmission problem, automatic has no reverse or OD
I have a 1999 eclipse spyder, 2.4L with an automatic transmission. Tranny is an F4A23
the tranny gave out recently and if I drive with the ODon then I have no reverse and when it gets to OD, it slips into neutral instead.
If I drive with OD off, then I just have no reverse.
Another symptom is that it shifts very hard into 2nd... but not bad at all into 3rd.
I did pull it and rebuild it recently and it has the exact same problem.... I obvioulsy overlooked something.
I plan to pull it again (what fun) and go through it once more.
I am hoping that I might get some good advice, from someone that has dealt with this already, on what to look for.
Thanks!
Old Oct 16, 2008 | 04:41 PM
dsm1990gsx's Avatar
Default RE: Transmission problem, automatic has no reverse or OD
What did you replace before and do u have any check engine light or trans light on?
Old Oct 16, 2008 | 09:46 PM
ccamaro98's Avatar
this website seriously has everything you need for a mitsubishi
63DH8
11
Sep 23, 2014 10:31 PM
Kenneth Iloka M
Oct 8, 2013 07:27 PM
basset29
Sep 23, 2012 06:38 AM
mchang40
May 7, 2010 06:04 AM
blloyd18
Mar 29, 2008 02:14 PM
