Warning lights in Lancer not lighting up.
Old Jul 18, 2014 | 03:30 AM
Sathya's Avatar
Default Warning lights in Lancer not lighting up.
Hi All,
I have a Mitsubishi Lancer 2001 (Indian model), All the warning lights seems to malfunction.
My Car runs fine but
1) The Check engine light never comes on (Even during Ignition)
2) The Low fuel light never turn off (Does turn off when I run into potholes)
3) The Oil Pressure light never comes on during ignition but lights up when I run into potholes.
All the bulbs were replaced to eliminate blown out bulb issues.
Any help / Suggestions will be appreciated.
Old Jul 18, 2014 | 04:54 AM
Sathya's Avatar
A few hours in Rain fixed the OIL pressure light issue ... Any suggestions??
Still have issue with the Fuel and the check engine light.
Old Sep 24, 2014 | 12:48 PM
Akzle's Avatar
loose earth connection in/ under dash.
Old Sep 25, 2014 | 04:03 AM
Sathya's Avatar
Thanks for the replies guys
Here is what I did for the Warning lights.
1) Fuel light which stayed on Always.. Fixed the issue [I knew it was a problem with thermistor and managed to get a thermistor from local electrical store a 680 Ohms thermistor for a couple of cents.]
2) Oil light pressure light... [Damaged oil pressure switch which I did not manage to find anywhere near my place.. So did not fix.]
3) Check engine light is still not working as it might be an issue with ECU.. No ECU experts near my place so not bothering to fix as it could fry my ECU and render my car useless
In short the car is pretty good working order except the annoying oil light...
tyo85
Mar 13, 2013 03:42 PM
micowave
40
Jul 17, 2007 11:20 PM
jaday
Jun 28, 2006 02:36 PM
Samis04
Jun 7, 2006 05:22 PM
cess_king
Dec 8, 2004 02:39 PM
