Where is the Camshaft Position Sensor?? Help please
Old Apr 17, 2006 | 06:11 PM
Sephiroth's Avatar
Default Where is the Camshaft Position Sensor?? Help please
Hi, i have trouble with my 00' gt eclipse suddenly it started to stall and the rpm gauge whent crazy i drove to the nearest checker and they run the diagnostic. Two codes appeared:
P0335 Crankshaft Position Sensor A Circuit Malfunction
P0340 Camshaft Position Circuit Malfunction
I want to know where are these sensors or if i only change the camshaft sensor would it be enough for the car to drive normally, i've seen in threads that there are cars that run good after the change and others that dont, please help me, and if someone can give me an ilustrated instruccions or detailed. Thank you.
Old Apr 17, 2006 | 10:37 PM
Sanguinius's Avatar
Default RE: Where is the Camshaft Position Sensor?? Help please
I'll look in my manual when I get home but the can position sensor will be on the left or right side of the engine likely on the backside of the head.
Old Jun 4, 2006 | 03:03 PM
eclipse21's Avatar
don't know if u already got it fixed or not but the crankshaft position senor is located on the front of the engine inside the timing belt cover i got it out of repair manual book so thats where it should be located
Sephiroth
Feb 25, 2018 07:46 AM
Dookitchen
Mar 22, 2007 11:49 AM
Rogo
Nov 23, 2005 03:12 PM
Jeffb1
Oct 1, 2005 04:51 PM
michael49
May 16, 2005 10:30 PM
