wont start
Old Dec 23, 2005 | 09:00 PM
350 style's Avatar
Default wont start
i recently got a 91 eaglel talon but when i was driving it the othere day it just died as i was switching gears i started it back up no problams for about a mile then it died again finally i pulled over to see what was going on but after i looked at the engien and tryed to start it again it wouldent start .the motor is turning but it wont fire up it has spark and fuel the timing is right too. i cant figure out whats wrong with this thing please help
Old Dec 23, 2005 | 09:51 PM
Sanguinius's Avatar
Default RE: wont start
Check the ECU. Open it up and see if there are any marks on the board. You may have been a victim of the ECU Capacitor leak.
Old Dec 24, 2005 | 07:54 PM
Joel_CA's Avatar
When you say you have fuel, are you referring to fuel pressure or injector pulse? A failed ECU will prevent either spark or injector pulse (more likely injector pulse). Use a noid light to see if you have injector pulse at the fuel injector connector. If not- your ECU has failed.
Joel, CA
GryphonsClaw
Jun 21, 2006 11:33 PM
03LancerT28
May 13, 2005 12:20 AM
red92eclipse
Oct 22, 2004 12:38 PM
95rs
Aug 24, 2004 08:09 PM
mach1
Jul 22, 2004 06:52 PM
