2003 Mitsubishi Lancer NO CRANK ISSUE
Old Jun 7, 2022 | 10:37 AM
MistyDragon's Avatar
Default 2003 Mitsubishi Lancer NO CRANK ISSUE
2003 Mitsubishi Lancer: New starter, new battery, new ignition switch, and new alternator.. it seems the more I drive and the longer I let it sit the more times I have to turn the key to make the starter spin. Does anyone know where the starter relay is located on it? Cause I can’t find it anywhere, or does it not have one? And could it also be the neutral safety switch? It’s a manual 5-speed or does it not have a neutral safety switch? Also any grounds I should look at cleaning? I’ve cleaned 2 grounds that I have seen but I’m sure there’s more, I just don’t know where they are. Any advice will help, THANK YOU GUYS
Old Jun 8, 2022 | 07:30 PM
Default Issue resolved (sort of)
I got pissed and just decided to run two wires from the starter (one from the signal terminal[the flat terminal on the starter] and the other from the positive terminal on the starter) and when you connect them, it spins the starter, and I just put a switch on it and it works great! in conclusion.. Mitsubishi ignition systems are awful! And just run a switch to the starter!
1994eclipse
1st Generation
Feb 3, 2019 08:30 AM
pinkerpv
Apr 19, 2018 07:57 PM
latham
May 6, 2016 05:41 PM
MrSeriousMojo
Jun 28, 2012 10:26 PM
94sr
Jul 5, 2007 01:20 AM
