acceleration problem
Old Apr 25, 2015 | 10:24 PM
jesus m's Avatar
Default acceleration problem
hi i have my 95 mitsubishi eclipse gs and lately its been choking on the speed and the engine its a little shaky when accelerate and throws this funny smell like some liquid is burning and sometimes the car starts turning off when the engine its cold...i need some help please and thanks
Old Apr 25, 2015 | 10:42 PM
Akzle's Avatar
jesus drives an eclipse.
what you need, is a mechanic.
Old Apr 29, 2015 | 02:41 AM
81cb900's Avatar
Unfortunately, there are way too many things that could cause this and you don't have enough information for a solid theory. I would start with a code reader to see if there are any error codes, even if the engine light is not on. Does anybody here know if there is a way to pull engine codes without a reader, like on the older GMs?
If not, it could be that a sensor is going out and is reporting the wrong data, but not enough to trigger a code. It could be an ignition coil or spark plug that works fine at idle, but can't handle higher RPMs. Maybe clogged fuel injectors or a weak fuel pump.
It may take hours of testing sensors and cleaning components to find the problem. So, I think Akzle is right, you need a mechanic.
But try the code reader first.
Donas
Apr 14, 2014 01:20 PM
Genosyne
Aug 21, 2008 06:59 PM
jcasaccio
Apr 8, 2008 03:21 PM
eclipse27
Dec 6, 2005 03:24 PM
dennistan80
Jul 21, 2005 04:14 AM
