clutch problem.. please help
Old Feb 7, 2009 | 05:28 PM
ashour's Avatar
Default clutch problem.. please help
could someone help plz?
i just changed the gearbox on my 94 galant viento, and after i finished evrything, i started the car but i can't move the stick to any of gears or reverce.it moves when the engine is off, but whe i put it to 1 then i start the car, i can feel the car started moving without taking my foot off the pedal, which looks like the clutch is too low.
i changed the slave slndr but still the same.
dou you think it could be the master slndr or pressure plate?
cheers
Old Feb 7, 2009 | 05:32 PM
dsm1990gsx's Avatar
Default RE: clutch problem.. please help
Did you bleed the air of the system?
Old Feb 7, 2009 | 05:35 PM
ashour's Avatar
you mean on the slave slndr? yes i did
Old Feb 7, 2009 | 05:39 PM
dsm1990gsx's Avatar
Well if all the air is out I'd say something is wrong w/ the pp. Sounds like its staying engaged.
Old Feb 7, 2009 | 05:49 PM
ashour's Avatar
ohh man that means i have to do it all over again
thanks so much anyway.
Old Feb 7, 2009 | 05:51 PM
dsm1990gsx's Avatar
Did you replace the clutch and pp when you replaced the trans too?
Old Feb 7, 2009 | 06:52 PM
ashour's Avatar
yes i did. actualy i bought this car with brocken Gbox, and the clutch was still attached with the Engine, i took it out, cleanded it then put it back on. do you think if the clutch disk was put on wrong side will do this? but i'm sure i put it the right way, which is the long hub side out side facing the Gbox shaft
Old Feb 7, 2009 | 07:28 PM
dsm1990gsx's Avatar
The clutch disc should be able to go in one way and you shouldn't clean or touch the clutch disc at all.
Old Feb 8, 2009 | 10:59 PM
ashour's Avatar
hi again..
do you know how many Liters does the manual gearbox of galant V6 takes?
thanks
Eclipseprince
Mar 12, 2009 04:53 PM
Eclipseprince
Mar 10, 2009 04:19 PM
switch_blade802
Mar 28, 2007 12:32 AM
BlackMurcielago
Jan 24, 2007 11:29 PM
koodalgo
Mar 28, 2006 12:07 AM
