clutch problem to stiff at bottom
Old May 9, 2008 | 12:47 AM
shortbusryder's Avatar
Default clutch problem to stiff at bottom
i have a1998 mitsubishi eclipse spyder 2.4 non turbo, just replaced clutch and slave cylinder. my problem is the clutch is soft until 3 or 4 inches off the ground and then you got to push really hard to get it to disingaug, or to hit the switch to get started. ive bled it and tried to adjust the pedal but no luck.any ideas
Old May 9, 2008 | 01:04 AM
Default RE: clutch problem to stiff at bottom
Just a heavy pressure plate.
Old May 9, 2008 | 01:37 AM
does it break in, or is it just a crappy clutch?
Old May 9, 2008 | 10:40 AM
bump
Old May 9, 2008 | 02:09 PM
It will change a little. Thats pretty normal, new clutches are pretty hard to drive on the first few miles. Just treat it right, don't beat on it, and it will do you proud.
Old May 13, 2008 | 09:01 AM
its soften up a little but still stiff. could it be master cylnder or should i throw a better clutch in there? dealer or after market?
Old May 13, 2008 | 03:02 PM
Seriously dude it will get softer. There is absolutly nothing you can do.
There is a very slight chance the master cylinder is a little sticky.... might want to check it out.
You can also adjust the clutch pedal so that it eliminates that last little part.
Andy_V
Oct 6, 2014 06:56 PM
chappy239
Dec 10, 2012 07:52 AM
da157328
Aug 7, 2007 10:10 PM
isaiah33
Jul 16, 2007 10:32 PM
mdungelman
Jul 14, 2006 07:11 PM
