Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Getting about 10-15mpg, is my custom intake causing this?
Old Aug 15, 2007 | 06:13 PM
Azazel's Avatar
Default RE: Getting about 10-15mpg, is my custom intake causing this?
Ok...so I'm gonna go ahead and take off the clamps and check the sensor. How can I check the catalytic converter?
Old Aug 15, 2007 | 06:20 PM
You really cant yourself.
Old Aug 15, 2007 | 06:22 PM
Azazel's Avatar
OK, here are some pics I took after removing the filter, which was actually kind of loose. Also, there is a spot on the filter that probably doesn't affect anything but I thought I'd include it in the pic...
http://www.tccommerce.com/images/filter.jpg
http://www.tccommerce.com/images/inside.jpg
http://www.tccommerce.com/images/pipe.jpg
Old Aug 15, 2007 | 06:23 PM
Azazel's Avatar
btw, that avatar is ****ing awesome...haha
Old Aug 15, 2007 | 06:26 PM
LOL thanks.
The pics dont work. Are you saying the black box was loose? Or just the filter? If it was just the filter then its okay.
ComposeEvo's Avatar
404 not found
The pictures are not available.
are you having any performance issues, such as sputuring, bogging, shaking through the powerband?
Old Aug 15, 2007 | 06:30 PM
Azazel's Avatar
Links are fixed, sorry.
By the black box, you're not referring to the hose...? Yeah, just the filter was loose.
ComposeEvo,
When I first started driving it two days ago there were very noticeable performance issues, some of it was caused by the tires, which have been replaced. Also, there was a slight miss and stutter at about 65+mph, but I believe that was caused by a loose connection from one of the spark plugs. My friend noticed it, fixed it, and said that one of the cylinders wasn't even firing. I only drove it home from there, but I didn't notice the miss/stutter at all.
Old Aug 15, 2007 | 06:32 PM
I think after re setting the ECU and after about 200 miles the car should learn how to run again.. it should be fine. By the way.. dont go wide open throttle for the first 15 mins of running after the ECU is reset.
Old Aug 15, 2007 | 06:38 PM
Azazel's Avatar
Maybe this is how it's supposed to be, but this doesn't make much sense to me...look at this picture
http://www.tccommerce.com/images/mystery.JPG
Is there supposed to be something fitting into the that hose on the bottom?
Old Aug 15, 2007 | 06:40 PM
AAAH IM SO STUPID. Its a 420a. They dont have MAF sensors. (the black box) sorry!
Well i would reset the ECU and see how that goes first
