Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Getting about 10-15mpg, is my custom intake causing this?
Old Aug 15, 2007 | 09:24 PM
  #41
Default RE: Getting about 10-15mpg, is my custom intake causing this?
See how it drives now that the ECU is reset
Old Aug 15, 2007 | 10:53 PM
  #42
Azazel's Avatar
ORIGINAL: blamesociety
hm. yah that little nipple is suppose to connect to the intake via hose
but yah. i wouldn't think something like that would take away any mpg. but it might. so maybe it'll fix it? try it out.
Thanks...do you happen to know the name of the hose or the nipple it connects to? (that sounds hilarious, doesn't it?)
Anyway, that will help me look for it in some salvage yards. There's no way in hell I'm gonna let some dealership charge me $50 for that thing.
Old Aug 15, 2007 | 10:58 PM
  #43
Azazel's Avatar
ORIGINAL: Sebba
OK. Haven't driven it since resetting the ECU, I hope it doesn't fall the **** apart tomorrow. lol I read somewhere that you really shouldn't do that...between reconnecting that loose plug, tightening the air filter, and resetting it, I really hope this is fixed.
Old Aug 16, 2007 | 02:27 AM
  #44
blamesociety's Avatar
hm. you could prolly just get the same type of tubing at a local parts store for a couple bucks if not less. that hose came with the intake, i actually had to cut it to fit right so it wouldn't be creased and bent. ill look up what it is later. late!!
Old Aug 16, 2007 | 08:17 AM
  #45
Azazel's Avatar
OK, thanks...
Old Aug 16, 2007 | 10:26 PM
  #46
Azazel's Avatar
Today I filled up from below E and drove just under 100 miles, more highway than city and shifting at about 3-4k RPM. I will be at half a tank within the next 10 miles or so. This was from above 'F'. So mileage is still pretty bad...you said the ECU reset will need about 200 miles to show real improvement?
Old Aug 16, 2007 | 11:01 PM
  #47
Well.. 200 miles to get to where it should be. Hmmm its really hard to say what could be doing it.
Could be that crappy intake+filter
Could be that vacume line
Could be a bad o2 sensor
Bad injector? (loooong shot)
Old Aug 17, 2007 | 05:25 PM
  #48
Azazel's Avatar
OK guys, I got a diagnostic run and here are the results:
DTC (Codes)
P1698
Manufacturer Control
Auxiliary Inputs
Auxiliary Outputs
P1899
Transmission
P0171
System Too Learn
(Bank 1)
DTC Pending (Codes)
No faults detected.
What do you think? And how can I check to see if he disabled the check engine light, because it should've definitely been thrown, right?
Old Aug 19, 2007 | 02:07 PM
  #49
Azazel's Avatar
What about a 3-step fuel injection cleaning? Think dirty fuel injectors could be causing or contributing to this?
car4lyfe
Apr 18, 2012 07:32 AM
GREDDY_GST
Aug 15, 2007 06:11 PM
matt02708
May 11, 2007 10:18 PM
5Tizzle
Oct 13, 2006 06:41 PM
5Tizzle
May 27, 2006 08:34 PM
