My 1997 Mitsubishi Spyder will not go past 15mpg HELP!
Old Apr 17, 2012 | 08:05 PM
car4lyfe's Avatar
Default My 1997 Mitsubishi Spyder will not go past 15mpg HELP!
I meant to say 15mph.
I just recently bought a 1997 Mitsubishi 2.0L turbo charged 4-speed automatic Spyder.
Unfortunately, as i hit anywhere from 13-17 mph, the car starts to die out, and black smoke comes out of the exhaust pipe.
If you could please help, it would be greatly appreciated!
Thank you.
Old Apr 18, 2012 | 07:32 AM
bigmike2112's Avatar
Does the car completely die out at that speed?
How does it idle?
Hows your gas mileage, do you notice gas just disapearing anytime you drive it?
Black smoke = burning to much fuel. Usually has something to do with the Air to fuel ratio, so for instance, say you have a bad intake gasket leak, now you have air entering the engine that is passing the actually throttle body and not being recognised. So when the engine gets this burst of air, it causes the fuel pump to dump more fuel into the engine. So basically when that happens, your flooding the engine with fuel, causing it to shut down/run like crap. I'd start off by checking your whole intake system for leaks, maybe any wires unplugged, anything that doesn't look right.
dubs05
Feb 28, 2015 10:30 PM
bo0st
Aug 2, 2012 06:32 PM
Azazel
Aug 19, 2007 02:07 PM
riphamra
Nov 16, 2006 09:38 PM
ktown
May 29, 2006 10:47 PM
