Internal Lounge Chat about beefing up your insides here.
Knocking help....
Old Sep 3, 2007 | 11:27 AM
dirtracineclispe's Avatar
Default Knocking help....
Started the car up and when i hit the gas you can hear a knocking sound. Any ideas of what that is? I have heard rod bearings. How do I change/check those?? Can I do it myself?? Please help.
Old Oct 25, 2007 | 06:53 PM
dsm1990gsx's Avatar
Default RE: Knocking help....
Try singling out the noise to a cylinder.
Old Oct 25, 2007 | 09:20 PM
nick_200321's Avatar
if you find out it is the rod bearings, which it very well could be, yes, if you know some about cars you can do it yourself.. drain oil, drop pan, remove connecting rod, drop the piston, and your rod bearings will either fall off, be stuck on the crank journals and need taken off, or be on the connecting rod..
MitKridly
Mar 19, 2009 11:27 PM
2fast4you
Sep 6, 2008 04:56 PM
thomas4g63
Apr 3, 2008 10:47 PM
keepitstock
Jun 23, 2006 07:22 PM
bterwilliger
Jul 1, 2004 01:54 PM
