94 3000GT SL Problems help pleasee
Old Aug 6, 2011 | 11:24 PM
datboricuaking's Avatar
Post 94 3000GT SL Problems help pleasee
Ok the car was running completely fine i had a gas tank problem couldn't fill it up it would leak outta the tank so i got that fixed and here comes the problems. i drove the car it wouldn't go passed 3rpms and when i let go of the gas it would just feel like its stalling ( it is a stick shift ). now the car is basically starving it doesn't turn on i tried a working MAF sensor it did turn on just alil and then turned right off in like 2 seconds i can't even rev it up to keep it on it just goes right off. the battery's good the lights work the dash lights up everything. however when connecting to computer to read what's wrong with the engine because the check engine light did come on because regular gas was accidently put in but the lights off now but i do get a error code when trying to connect to read anything. any tips i kno this seem pretty weird but maybe someone can actually help me with this. thanks
Old Aug 8, 2011 | 05:04 PM
Girly VR4's Avatar
running regular gas won't throw a CEL. I run regular in mine all the time.
It could be a fuel delivery problem, that would be my best guess. There's really no way to diagnose this over a forum though. Where are you located? I'd recommend bringing it to a shop to have them diagnose your problem.
Old Sep 7, 2011 | 01:41 PM
redtoolbox's Avatar
Default I get it
what you've explained is the same problem i am having. you posted it over a month ago and i was wondering what you did to fix it. i replaced the MAF and same problem, wont stay started.
what did you end up doing?
thank you
Old Sep 10, 2011 | 09:26 PM
mxmikie's Avatar
tps sensor
Old Sep 13, 2011 | 04:30 PM
redtoolbox's Avatar
Its not the tps, I can keep the car running as long as i keep my foot on the gas pedal a little. but once you let off the car stalls out. Before i replaced the MAF you could unplug it and it would run just fine. And after i replaced the MAF it ran fine for a week then problem came back. And now try unpluging the MAF the problem still occurs. HELP!!!!!
jp2000
Jan 1, 2012 05:21 PM
p4c0
Feb 22, 2007 06:36 PM
3000vr4conquesttsi
Jul 28, 2005 12:40 AM
enzo_hashmat2006
Jul 9, 2005 05:02 PM
3kgthoney
Apr 30, 2004 12:00 PM
