Boost controller help
Old Nov 25, 2005 | 01:15 AM
saynotovtec's Avatar
Default Boost controller help
I have a completely stock 1993 VR-4 with about 45,xxx on the motor. I'm looking at www.3sxperformance.com right now and I see boost controllers for sale for like $80. How hard is it to install these? How much boost can it handle completely stock? How do they work exactly? Do I need to install other parts with this part? What kind of power gains will I see?
Old Nov 28, 2005 | 08:11 AM
Jomojr's Avatar
Default RE: Boost controller help
Hiya,
You should go check out 3si.org under the AWD section. You can find a wealth of information regarding your car there. Regarding the boos controller, I assume your talking about a manual one. The stock 9b turbos will hold about 10psi to redline. You can spike them much higher than that. I believe that the stock boost controller on your car is set to 12psi "double check that" What you really need is a way to monitor knock. I use a scanmaster3 to monitor my car so I know how much boost is safe. Turning up the boost wth a manual controller and not having a way to monitor the car is playing russian roulette with your motor.
2nd g eclipse gst
Jul 14, 2006 09:44 AM
cvilledsmr
Jan 4, 2006 12:10 AM
93VR4
Jul 29, 2005 12:17 AM
Knaackers
Jun 25, 2004 08:14 PM
Knaackers
Jun 25, 2004 06:01 PM
